We were using our connection to game on our PS4 and PC, and for the past handful of months I have been unable to due to an unreliable ping.
I test the ping to Google.com, Yahoo.com and 8.8.8.8 and will get under 100 Ms for a duration of time, and then it will spike to around 1000ms. I'll get ping results around 60ms for 15 minutes to an hour, then over 500ms to 1k for 15 minutes to an hour, and then it will go back and start the loop over again.
I have been trouble shooting on my end to try and narrow it down and I think it's likely it's the tower we use and was hoping to have Verizon Support look into it. The area code is 37874.
Steps I have taken is to make sure that nothing but the PC is connected to the network, Also to connect to the WIFI from the Verizon Router instead of the wired connection using our router. I have tried other PC's and a Laptop. I have even connected my phone and got the same results. Some times it's fantastic, other times it's not usable.
I have noticed the same results from my Verizon Wireless phone when it is not on the home network at all. I also enabled the hotspot from it and connected a laptop and would get similar results.
I am not sure if it's coincidental or not, but a tornado came through in November and destroyed several homes a couple of miles from me and it may have started around then.
Thanks in advance for any help.
