Garage PC is too far away from Verizon Wireless Router MI424WR.
The cable from the underground comes in at the garage and is tantalizingly close!
Can a 75 ohm video type splitter be installed at the garage and some sort of converter box be installed at that point to convert the signal and provide a hardwire connection to the network card in the garage PC?
If possible, does Verizon have this converter for a reasonable cost or can you recommend an alternative?
Can an extra STB from Verizon be installed and use the "ETHERNET" RJ45 connector on the rear panel?
