During power outages, my Fios ONT (GPON) used to shut itself off and had to be rebooted by the ISP's central bank. This was a nightmare during power outages--and we have a lot of them where I am. I have solar power with Tesla Powerwalls backup for my house, but the PWs take a few milliseconds to kick in, and this caused the ONT to shut itself down.
To solve this, I bought a CyberPower ST325 , and plugged the ONT into it. It worked great for 4 years until it died of old age. I replaced it with a CyberPower ST425..
Unfortunately, after I did so, I started having brief but constant intermittent internet outages. For example, in 3 days there were 60 outages lasting 1-2 minutes each.
An ISP came out and saw that the wifi signal was too "hot", so he upgraded the GPON ONT to an XPON ONT because (I think) it has greater bandwidth.. 4 hours later, I started having multiple mini-outages again.">
Another ISP tech was dispatched to inspect and when he saw the ONT was plugged into the Cyberpower UPS, he said that he'd seen that particular UPS cause multiple mini outages similar to mine.
So, I unplugged the ONT from the UPS and plugged it directly into the wall socket.
VOILA! No internet outages since.
I learned that pure sine wave UPS systems provide cleaner, smoother power output than simulated sine wave UPS systems. Pure sine wave output is identical to utility power and can safely run sensitive electronics like computers and medical equipment. In contrast, low end UPSs output a simulated sine wave with a stepped waveform that may cause issues for some devices—like my Fios ONT, apparently.
At this point, I still need a compact UPS that plugs into a wall outlet, that I can plug the ONT’s AC cable into, and that would allow the ONT to operate seamlessly, they way it should--without constant mini-outages.
The ONT does not draw a lot of power, and the UPS would only be providing power to the ONT for the milliseconds before the Tesla Powerwalls kick in. So I don’t need a maxed-out UPS, with USB inputs, etc.
Any recommendations?
