Phone and battery life were great up until the April one UI update. I have a battery tracker app and it shows I routinely used 40 to 50% of battery after 15 to 18 hours of usage with 2 to 3 hours of screen time before the update
After the April update its almost double that and my phone dies before end of date. This is ridiculous. This is a known issue talked about a lot on Samsung forums: https://eu.community.samsung.com/t5/galaxy-s23-series/battery-drain-after-one-ui-6-1-update-s23-ultra/td-p/9608861
We need Verizon to acknowledge and fix this asap or push samsung for a fix. I buy these expensive phones to make my life easier. Not to spend 5 hours debugging it and resetting and doing all sorts of stupid stuff every time you guys decide to push out an update without testing it. FIX THIS!!!! You can see pics below first is from before the update, second one is after the update where the whole battery is drained some days. Same usage almost, same apps, same settings on phone etc.
